2
This discussion topic has been answered Discussion topic: SkyQ Box picture stuttering and flickering
This message was authored by: SJOSJO
Our SkyQ box has started to experience picture stuttering and flickering today, which we cannot rectify.  The picture flickers off and on repeatedly at the same rate of about twice a second.  It happens for the TV picture but also when on menu.  We have tried a new cable but that is not the issue.  It appears to be the SvkyQ box itself, which is less than 3 years old.  I am wondering if this is a software update problem?
I have booked an engineer visit but the first available is 10 days away!
Avatar for SJOSJO
This message was authored by: SJOSJO Answer
Re: SkyQ Box picture stuttering and flickering
Thanks so much for all the help.
We had tried all the help options and it didn't work.  However, I asked my husband to try a software update (before reading the replies) and it worked! Fingers crossed it doesn't go back.
Hi @SJOSJO
Highly doubtful that it is a Software issue as this would effect all users.   There has been no Software updates for many months and doing a manual update when the Software is already on the latest version doesn't change the software.
First thing you should try is a Reset Settings in the Q box hidden menu.
Avatar for SJOSJO
Answered - Go to Answer
