Discussion topic: SkyQ 1TB Box - Watch TV in another room
This message was authored by: gillyp
I want to watch TV from my SkyQ box in another room, I dont need multiroom as the channel in the second room can be the same as the living room, just the same channel in another room!  Do I need the SkyQ Mni Box and is it a wireless connection?
If I add Multiscreen do Sky send me the mini box to add the connection?
Re: SkyQ 1TB Box - Watch TV in another room
@gillyp
Adding a Multiscreen subscription does not automatically add a mini box. Mini boxes have to be added in addition to Multiscreen.
Be aware the original 1TB (non-UHD) Sky Q box only allows one mini to be in use. To check if you have the non UHD 1TB box check in:-
If it shows as 32Cxxx then you have a non UHD 1TB that only supports 1 active mini box.
All 2TBs and the UHD/HDR 1TB permit two mini boxes. Each mini box which is loaned to you may be subject to a one off upfront charge but you only need one Sky Q monthly Multiscreen subscription.
Avatar for gillyp
Level 0 icon
Helpful, thanks, I only need one additional TV so one box is fine, so I just order the multiscreen and then gives me the option to order the mini box?  And does it connect over wifi or does the mini box need to be connected to the original SkyQ box?
@gillyp
Ours which is in our conservatory is connected via Wi-Fi. Had it since we moved from Sky+HD to Sky Q in 2019.
If you want to just 'mirror' the main box then you can look at HDMI extenders/repeaters.
Generally wired ones are more reliable (as per mini boxes).  There's an initial setup cost but no Sky subscription required.
