Discussion topic: Sky wont come on, just says check device, i have checked all connections and disconnected the sky q
This message was authored by: Lynne70
sky Q box is just showing check device, have turned everything off and checked connections all are OK,  have done this a few times and still not turning on , I'm getting the screen to press home button when it goes black and then instead of turning on its saying check device.
Re: Sky wont come on, just says check device, i have checked all connections and disconnected the sk
Hi @Lynne70 .
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
Avatar for Lynne70
Hi thanks , contacted sky they ran a test and I need a new box
