Discussion topic: Sky will not connect to broadband
This message was authored by: Billyblue44
We have Now broadband & as of this morning the sky box will not connect to the sky box. I keep putting the password in, but it says it is not correct.
Re: Sky will not connect to broadband
@Billyblue44
The Sky box will not connect to the Sky box? Sorry your going to have to be more specific.
I am NOT a Sky Employee
Avatar for Billyblue44
Sorry. The sky box will not connect to the Now Broadband. It says the password is incorrect. It hasn't been changed
@Billyblue44
If you have changed to Now Broadband surely the password has changed or are you saying your Sky Q box has been connected to the now broadband router previously?
We have been with Now for a year. This has just happened overnight.
@Billyblue44
Ah okay makes more sense.
I would start off by doing a network reset on your Sky Q box, then do a factory reset of your Now hub by holding the reset button on the back for 30 seconds. Then try and reconnect them.
Reset the Now box, but how do I do a network reset on the sky box
@Billyblue44
Settings > Network Setup > Reset
