Discussion topic: Sky w box not connecting to the internet
Message posted on 24 Sep 2023 12:35 PM
My sky Q box will not connect to 3rd party broadband provider, I've reset the network connection and tried the wprs button. My broadband is 5G and is over 300mbps.
Message posted on 24 Sep 2023 03:38 PM
							Re: Sky w box not connecting to the internet
@Bittonmonkey66 Sky Q main boxes will only connect to the 2.4GHz wifi band from 3rd party wifi. Sky Q minis can only be connected by wifi to a Sky SSID which where there is no Sky hub is provided by the main Sky Q box using the 5GHz band. Only other way to connect Q minis is by ethernet.
Message posted on 25 Sep 2023 11:21 AM
@Bittonmonkey66 wrote:My sky Q box will not connect to 3rd party broadband provider, I've reset the network connection and tried the wprs button. My broadband is 5G and is over 300mbps.
I don't think it's possible to connect the Q box to a 3rd party router using WPS. You have to select the non-Sky broadband option and select te SSID and enter the password to connect.
Message posted on 25 Sep 2023 11:44 AM
@Chrisee wrote:@Bittonmonkey66 Sky Q main boxes will only connect to the 2.4GHz wifi band from 3rd party wifi. Sky Q minis can only be connected by wifi to a Sky SSID which where there is no Sky hub is provided by the main Sky Q box using the 5GHz band. Only other way to connect Q minis is by ethernet.
I could be wrong but I think they meant it's using a 5G mobile network, not 5GHz wifi.
Maybe.
