Discussion topic: Sky viewing card wont go back in.
Message posted on 13 Mar 2023 04:49 PM
The sky viewing card popped out by itself and won't go back fully into the slot.
Message posted on 13 Mar 2023 05:10 PM
Re: Sky viewing card wont go back in.
@Ronnie2023Are you putting it in with the chip side up, if so contact Sky so they can change the box.
Message posted on 13 Mar 2023 06:41 PM
@Ronnie2023 you do need to push it in until it clicks. Its slightly spring loaded so to remove it you push it in and it springs out and when putting back in you need to push it till it clicks.
If it will not click then you will need a new box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
