2
This discussion topic has been answered Discussion topic: Sky tv stuck on sky news remote will not move menu but volume button still working on remote .
This message was authored by: LD80
Remote will not scroll through menu . Sky  Q box was stuck on amber light and had to press manually on box to change to green light and  Sky home page .
Re: Sky tv stuck on sky news remote will not move menu but volume button still working on remote .
Hi @LD80
Reset your Q box remote by pressing  and holding 7 & 9 together on the remote until it’s led flashes four times.
This will set it to infrared which will work all Q boxes.   However the remote must be pointed directly at the Q box.
Switch your Q box back on and you then you should be able to get past the scrolling issues.
Once you get the Q box working make sure that you are pointing your remote at the Q box and press 1 & 3 together until the remote led flashes and follow onscreen instructions to re- pair.
Hi @LD80
Avatar for LD80
Thank you so much for your help it worked !  nothing worse than a remote stuck on Sky News 🙂  thank you for taking the time to reply enjoy the rest of your Saturday !
