Discussion topic: Sky tv signal completely breaks up so tv is unwatchable
Message posted on 18 Jul 2024 07:44 AM
Just moved into new house. Have sky q and 4 mini boxes served by communal dish. Signal breaks up completely at certain times ?
Message posted on 18 Jul 2024 07:50 AM
Re: Sky tv signal completely breaks up so tv is unwatchable
Are you seeing an error message of 'no satellite signal'? If so check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check the troubleshooting in this link
As you are connected to a communal dish you’ll need to liaise with you building management company / landlord who will have their approved engineers to contact. Perhaps check if neighbours are having the same issue.
Note: A misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
