Discussion topic: Sky tv not working the screen is frozen
Message posted on 07 Aug 2025 04:10 PM
My sky tv is frozen on the home screen
Message posted on 07 Aug 2025 04:15 PM - last edited: 07 Aug 2025 04:16 PM
Re: Sky tv not working the screen is frozen
Hi @Nina15
Have you tried rebooting your Q box?
If you had to press th front button on the Q box to get it on , then With the Q box on with green led try completly resetting your Bluetooth remote.
