1
This discussion topic has been answered Discussion topic: Sky tv not working after trying all the steps
This message was authored by: Dan129
Sky tv not working, tried reset and tried reset then hold standby button for 30 seconds, message came up saying it was doing a update, now stuck with solid red light and flashing blue light on the 'Q'
Re: Sky tv not working after trying all the steps
Hi @Dan129
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
Hi @Dan129
Answered - Go to Answer
