Discussion topic: Sky tv not connecting to Sky router
Message posted on 16 Apr 2024 07:20 PM
Sky tv not connecting to broadband router
Message posted on 16 Apr 2024 07:44 PM
Re: Sky tv not connecting to Sky router
Hi @Susanfox36
