Discussion topic: Sky tv intermittent and freezing apps not loading
This message was authored by: Kazza72
When I turn TV over programme takes ages to load. Recordings catchup says technical fault unable to load netflux and paramount half of apps not showing. I've switched everything off reset unsure of problem. Thank you
Re: Sky tv intermittent and freezing apps not loading
Hi @Kazza72
I suspect the reset you have done is just a reboot.
If you still have issues best to contact Sky for an Engineer.
