1
This discussion topic has been answered Discussion topic: Sky tv freezes when talk into microphone to search
This message was authored by: Gary.+N
Pressed blue microphone to search programme name comes up but then sky freezes
This message was authored by: Doc5907 Answer
Re: Sky tv freezes when talk into microphone to search
Try a Reset Settings in the hidden menu to see if that solves your issue.
Scroll down to Reset
After the Reset you may have to re pair your Bluetooth remote If you use one.
Sky Q 1TB UHD
LG TV
Sky Mobile
Sky Q 1TB UHD
LG TV
Sky Mobile
