10 Jun 2024 11:47 AM
Sky tv booster only has 2 green lights, tv sky mini jumping screen
10 Jun 2024 12:00 PM - last edited: 10 Jun 2024 12:01 PM
Hi @Rita+z
If your Q booster is located between your Q box and your mini to aid the mini connection try reconnecting it.
Hold the WPS button on your booster for 3 seconds until it flashes amber. Then hold the WPS button on the front of your Q box for 3 seconds until it flashes amber - You'll need to do it within 2 minutes.
After a few minutes, the connected light should turn green.
Once you have all three green lights on the booster check the mini.
If you still have an issue with the mini connecting carry out a Network reset on the mini.
Highlight Status and then select Reset on the right hand side. Follow instructions to WPS with Q device.
You will be asked to press the WPS button on the Q booster (not the mini as the Network reset will start the mini WPS automatically).
10 Jun 2024 12:19 PM
Posted by a Superuser, not a Sky employee. Find out moreSorry, what does "jumping screen" mean?
