Discussion topic: Sky sports
This message was authored by: Woller
Sky sports
Hi can you please tell me why I pay for sky sports hd channel 401 but says that I'm not subscribed? But channel 402 works?
thank
you
Re: Sky sports
thank
you
hi @Woller
401 is SKY Sports Main Event - it is possible that the 'Smart switch' has incorrectly put the UHD version for you in slot 401 without you having the UHD add on
If you don't have the UHD add on trying looking at slot 858 (or around that ) for SKY Sports ME HD
Avatar for Woller
Re: Sky sports
Thank you for the reply
