Discussion topic: Sky sports +
Message posted on 10 Sep 2024 12:26 PM
Sky sports +
I'm getting code WGT8 when trying to use sky sports +
I have a full sports subscription so not sure why this is happening
Message posted on 10 Sep 2024 12:31 PM
Re: Sky sports +
@DavidArcher
Try a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if necessary-
~ press the 🏠 button
Also check your box is on the latest software Q270.
Message posted on 10 Sep 2024 12:42 PM
Re: Sky sports +
Hi, thanks I've done that and hasn't worked.
the software is Q230 so doesn't seem to be the latest version even though the SkyQ box is only 1 week old. Any suggestions please?
Message posted on 10 Sep 2024 12:44 PM
Re: Sky sports +
Update it to the latest software. This worked for another customer with that error code (albeit a few months ago).
Message posted on 10 Sep 2024 12:46 PM
Re: Sky sports +
@Daniel0210 wrote:Update it to the latest software. This worked for another customer with that error code (albeit a few months ago).
https://www.sky.com/help/articles/updating-sky-box-software-sky-q
Message posted on 10 Sep 2024 01:02 PM
Re: Sky sports +
Thanks guys I've updated the software to Q270 however the Code WGT8 is still there when I try to press the red button.
Message posted on 10 Sep 2024 01:32 PM
Re: Sky sports +
Try opening sky sports + from the App menu....
Home>>>>>Apps>>>>Featured >>>>Sky Sports
Sky Q 1TB UHD
LG TV
Sky Mobile
