6
This discussion topic has been answered Discussion topic: Sky sports password protected
This message was authored by: MC802
I wish to put a password on my sky sports package as I cannot get out of contract
This message was authored by: SKY1992bf Answer
Re: Sky sports password protected
@MC802  are you referring to being able to permanently lock the channels via the sky Q box epg meaning you require the PIN code every time you want to access them? that's the only possible way I know of
That's certainly possible on a sky plus hd box under settings parental control and pin but I'm not sure if it's possible on Q
cc @Daniel0210
@MC802
Not sure what you're trying to do and why?
Avatar for MC802
I would like a password to be entered to watch sky sports, Netflix (apps) etc and why is my decision to make. Thank you for your reply
Look under parental controls in Settings.
You can enable a PIN for Apps and the level of TV rating.  (If the Sports channel has a rating of 'U' then you can enable a PIN - but not all programmes have a rating)
cc @Daniel0210
Yes, I've just tested it.  You can enable PIN for even 'U' rated transmissions.  (But not all broadcasts have a rating)
(But this is not just for Sports channels - it applies to all)
Avatar for MC802
Yes it is thank you
