This discussion topic has been answered Discussion topic: Sky sports password protected
Message posted on 04 Dec 2025 04:14 PM
I wish to put a password on my sky sports package as I cannot get out of contract
Message posted on 04 Dec 2025 05:58 PM
@MC802 are you referring to being able to permanently lock the channels via the sky Q box epg meaning you require the PIN code every time you want to access them? that's the only possible way I know of
That's certainly possible on a sky plus hd box under settings parental control and pin but I'm not sure if it's possible on Q
cc @Daniel0210
Message posted on 04 Dec 2025 04:19 PM
Re: Sky sports password protected
Not sure what you're trying to do and why?
Message posted on 04 Dec 2025 05:40 PM
I would like a password to be entered to watch sky sports, Netflix (apps) etc and why is my decision to make. Thank you for your reply
Message posted on 04 Dec 2025 05:57 PM - last edited: 04 Dec 2025 06:01 PM
Look under parental controls in Settings.
You can enable a PIN for Apps and the level of TV rating. (If the Sports channel has a rating of 'U' then you can enable a PIN - but not all programmes have a rating)
cc @Daniel0210
Message posted on 04 Dec 2025 06:02 PM - last edited: 04 Dec 2025 06:03 PM
@SKY1992bf wrote:That's certainly possible on a sky plus hd box under settings parental control and pin but I'm not sure if it's possible on Q
Yes, I've just tested it. You can enable PIN for even 'U' rated transmissions. (But not all broadcasts have a rating)
(But this is not just for Sports channels - it applies to all)
Message posted on 04 Dec 2025 06:10 PM
Yes it is thank you
