Discussion topic: Sky sports+ not working
This message was authored by: Odsal3217
Doesn't load
Re: Sky sports+ not working
Hi @Odsal3217   I'm afraid that is just your box, have you tried a reboot of everything, including your broadband router to refresh its DNS.
@Odsal3217 wrote:
Doesn't load
@Odsal3217 you could try refreshing the apps in the engineers menu
To enter the engineers menu do the follow
press the home button then scroll down to setting and hi-light
do not press select/enter but press 001 then select this takes you into the engineers menu
scroll down to apps > refresh
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
