Discussion topic: Sky sports main event
Message posted on 18 Aug 2025 05:08 PM
Sky sports main event hd is not on channel 401, my is stuck on sky sports main event uhd, have updated the software etc and it's still there.
Can anyone help ?
Message posted on 18 Aug 2025 05:17 PM - last edited: 18 Aug 2025 05:18 PM
Re: Sky sports main event
@Hayley2812 If you have the UHD add on the the UHD version of said channel will show at 401, you also can't force a software update on a Sky Q box as it will be on the latest version.
Message posted on 18 Aug 2025 05:26 PM
Message posted on 18 Aug 2025 05:45 PM
Hi @Hayley2812 What have you got on channel 858?
Message posted on 18 Aug 2025 05:47 PM
@Hayley2812 wrote:
I've not subscribed to sky sports main event uhd though, I have all the other channel's in Hd
Hi @Hayley2812 Forgetting Sports, do you subscribe to UHD?
Message posted on 18 Aug 2025 07:08 PM
Sky sports main event HD. Just want it to be where it should be
Message posted on 18 Aug 2025 07:09 PM
No I dont
Message posted on 18 Aug 2025 07:59 PM
@Hayley2812 You could try refreshing your viewing card by pressing home > settings > system info > viewing card number > setup > viewing card setup press select to trigger a callback don't worry nothing to do with your phone its only Sky's terminology this will be done over the internet
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 17 Dec 2025 08:10 PM
How do I watch sport only on HD as sky stream is **bleep** doing UHD on live sports. So much stutter and F1 can't keep up with the cars. I've complained about this so much and sky never get back to me. Guess once you take the money your done. Hopefully Amazon or Netflix will buy the premier league soon
