Discussion topic: Sky sports buffers
Message posted on 11 Feb 2025 10:11 PM
Sky sports buffers
Upgraded tonight buffers all the time will cancel tomorrow
Message posted on 12 Feb 2025 06:07 AM
Re: Sky sports buffers
On live broadcasts?
Message posted on 12 Feb 2025 08:14 AM
Yes indeed I have over 50 mbps
Message posted on 12 Feb 2025 10:03 AM
@Colin107 wrote:Yes indeed I have over 50 mbps
That's irrelevant if your watching live as that is received via your dish
Message posted on 12 Feb 2025 10:25 AM
I see loads of comments regarding buffering football is there a fix or is it skys fault
Message posted on 12 Feb 2025 10:39 AM
@Colin107 wrote:I see loads of comments regarding buffering football is there a fix or is it skys fault
You're not making it clear what you are actually watching. If it's a live broadcast (which is received from the satellite into your dish) there can't be any "buffering"; you may get picture breakup if the dish is slightly out of alignment, but this is a different issue.
Message posted on 12 Feb 2025 10:44 AM
Sky sports+ live football on a mini box in separate room from main box. Could it be the connection between mini box and Sky Q box that sends signal to our two mini boxes
Message posted on 12 Feb 2025 11:20 AM
@Colin107 wrote:Sky sports+ live football on a mini box in separate room from main box. Could it be the connection between mini box and Sky Q box that sends signal to our two mini boxes
Ah, that's much clearer now. The Sky Q box & your mini are linked via Sky's own WiFi mesh, if they are too far apart, or have a lot of building structure between them, the signal can be reduced & hence cause buffering at the mini when it tries to recover the lost elements. Can you try moving the mini to a room nearer to the Sky Q to check that it can work correctly with a desent signal? If it does, you can request a booster box from Sky that you place 1/2 way between the Sky Q & mini to help improve the signal.
Message posted on 12 Feb 2025 01:37 PM
It's also relevant that Sky Sports+ matches (other than the one on the linear channel) are delivered over the internet rather than by satellite.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Message posted on 12 Feb 2025 03:04 PM
@oj01 wrote:It's also relevant that Sky Sports+ matches (other than the one on the linear channel) are delivered over the internet rather than by satellite.
So, with this in mind, check that any Sky Sports+ broadcasts are running without buffering on your Sky Q main box
Message posted on 12 Feb 2025 06:24 PM
Sound I checking that later tonight
Message posted on 12 Feb 2025 08:39 PM
It's perfect tonight how odd
