Discussion topic: Sky sports blinking
Message posted on 31 Aug 2025 04:51 PM
Sky sports blinking
Tv blinks, goes black for 1 second every few minutes while watching sports channels. Have tried resetting all settings on tv and sky q box and replaced hdmi cables and ports but no fix. Anyone else had the issue and fixed it?
Message posted on 01 Sep 2025 09:43 AM
Re: Sky sports blinking
Weird. What output resolution is your box set to?
Message posted on 01 Sep 2025 10:23 AM
1080i but I tried the other settings. I don't want to go any lower than 1080 when it's an Oled tv
Message posted on 01 Sep 2025 01:07 PM
1080p and 2160p both have the same issue?
Message posted on 01 Sep 2025 02:51 PM
Yes. 1080, 1080i and 2160 all the same. When you change ports or hdmi cables it works fine for about 10mins then you get the issue every few minutes. I've only noticed it on the sports channels but it definitely doesn't happen of I watched football on tv apps like amazon so it has to be related to sky box
Message posted on 01 Sep 2025 03:03 PM
What about BBC1 HD?
Message posted on 01 Sep 2025 05:16 PM
It works fine but I have to watch it through sky or iplayer but no issues from I recall. I don't tend to watch it much if I'm using sky
Message posted on 02 Sep 2025 05:06 AM
Sky or iplayer as opposed to what?
I meant on the Q box anyway. To see if there's a pattern to HD channels playing up.
Message posted on 02 Sep 2025 07:41 AM
No I haven't noticed any hd channels other than sports but as I say it's mainly sports I watch. Sky sports news doesn't seem to have the issue
Message posted on 02 Sep 2025 12:03 PM
Yeah that's why I'm suggesting you test them properly
seems extremely unlikely it would be a problem isolated to sports channels.
Message posted on 02 Sep 2025 01:46 PM
I have an engineer coming out tomorrow to look at it because I have tried anything that I can find to test myself
Message posted on 02 Sep 2025 02:29 PM
Does the 'blinking' start after ad-breaks? I have noticed something similar on channels that use Sky AdSmart and I know a few people have posted similar problems recently. Channels that don't use AdSmart like BBC and ITV are never affected.
Message posted on 02 Sep 2025 02:33 PM
I have only noticed it in the middle of football matches
Message posted on 03 Sep 2025 01:03 PM
Engineer came out and had to replace the box
Message posted on 03 Sep 2025 08:54 PM
Had a proper chance to test it yet?
