Discussion topic: Sky signal locked
Message posted on 07 Apr 2025 08:26 PM
Sky signal locked
Says sky signal locked and only 50%
Message posted on 07 Apr 2025 09:19 PM
Re: Sky signal locked
Should be Locked @Davidb12
If you have opicture issues in clear skies then work through the following link and if you cannot solve your issue it will lead to booking a Engineer.
Alternately, if you are on a Communal Dish you will need to contact your Landlord or Management company.
Message posted on 07 Apr 2025 09:19 PM - last edited: 07 Apr 2025 09:20 PM
In this context, 'locked' is a good thing (as in 'locked on target')
The signal strength, unfortunately, is not so good.
Message posted on 07 Apr 2025 09:56 PM
And is it working ok?
