Discussion topic: Sky screen says no signal (not satellite)
Message posted on 23 Sep 2024 07:31 PM
Turned the TV (Samsung Smart TV) as usual, switched back on and the sky screen just says No signal.
In the sources there is a red on/off icon by the HDMI.
The upstairs sky mini dish is working fine .
Could this just need a new HDMI cable?
Message posted on 23 Sep 2024 08:00 PM
Re: Sky screen says no signal (not satellite)
The upstairs sky mini dish is working fine .Could this just need a new HDMI cable?
Hi @Herbiedax
Are you sure that the Television is switched to the correct HDMI in put for the Q box?
Also is the Q box led Green?
Message posted on 23 Sep 2024 08:07 PM
I haven't changed the HDMI in the source's option and the only one.
It would appear that pressing sky on remote isn't turning the box on, it is amber only green if I turn it on at the box
Message posted on 23 Sep 2024 08:09 PM
Hi @Herbiedax
First make sure that the TV is switched on and is switched to the HDMI input to which the Q box is connected.
Then with the Q box switched on with green led illuminated
Press
Home 1 0 8 0 Home
on the Q box remote control.
This will change the Q box to standard resolution which will work for all TV’s.
Message posted on 23 Sep 2024 08:21 PM
Done all that and didn't work sadly
Message posted on 23 Sep 2024 08:26 PM
Hi @Herbiedax
Remove and refit the HDMI cable.
Then reboot your Television set.
Disconnect the television power lead for 30 sec then reconnect.
If you still have the same issue reboot the Q box.
Message posted on 23 Sep 2024 09:09 PM
Thanks, I will give it a try tomorrow.
Earlier I turned the tv off and the sky box for a few minutes but not in the order as you describe.
Under the stairs are huge bundles of cables and boxes for the sky, Sonos and Lord knows what else! can't see the forest for the trees!
Message posted on 24 Sep 2024 02:55 PM
Hi there
i am having the same problem, for over a week now. My sky q mini box switches on, the light is white. TV is on correct source for HDMI. just get a black screen with SKY in white, and then it goes to "No Signal". Have unplugged everything several times. AI chat is useless. Is it possible to talk to a human at SKY?
joyce
Message posted on 14 May 2026 08:31 AM
just turned on LG tv and sky q box got a green light on sky box but tv screen says no signal to fix the problem all I did was pulled out hdmi on the tv then turned tv off on the wall for a few minutes put hdmi back in and tv back on and it seemed to reboot the tv and after a few seconds I got the sky signal back
