Discussion topic: Sky remote won’t connect to sky mini box
This message was authored by: Sarahlee1969
Sky Remote control won't connect to mini box
Re: Sky remote won’t connect to sky mini box
Hi @Sarahlee1969
First reboot the Mini.
Wait at least 30 secs and then Plug back in and switch your mini box back on at the mains.
Wait for the on screen instructions to disappear and the front led to turn Amber. Then wait for 30 secs before you press Home on your Sky Q remote or if this is not working press the standby button on the front right of the mini box (Amber led)
If the remote is still not working then
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
