Discussion topic: Sky remote turns on tv, but comes back on in a few seconds
This message was authored by: Buryan
I want my controller to  continue on / if on my new tv
Re: Sky remote turns on tv, but comes back on in a few seconds
Hi @Buryan
Remember that a short press on the Remote standby button will switch the Q box On/Off.
If HDMI control is switched on in the TV and Q box settings,  switching the Q box On with a short press will also switch the Television On.  However switching the Q box Off with a short press will not switch the Television Off.
When the Q remote is correctly paired with the Q box and TV a long press on the Standby button (about 3 seconds) will switch the Television On or Off.
If Smart Standby mode is switched on in the Q box Settings (Home - Settings - Preferences) then switching the Television set Off with a long press will also turn the Q box Off.  A long press will never switch the Q box On.
