Discussion topic: Sky remote not working on Sky Q mini box
This message was authored by: Fatfield1953
Hi
pressing buttons nothing happening
Re: Sky remote not working on Sky Q mini box
As a first step, have you tried restarting the Mini, by switching off at the plug for a minute?
Avatar for Fatfield1953
Yes tried that, remote won't turn on the mini, did that manually, checked batteries all ok. Just nothing from remote.
This message was authored by: Leethemiller
I'm having this issue as well the remote has just stopped working. I can't even turn the sky box on and off with it.
This message was authored by: Grumpybear1
Remote won't work on sky q minibus
@Grumpybear1 @Leethemiller
Have you tried rebooting your Q box ie
then
Try resetting your remote.
Press the buttons 7 & 9 together on the remote until it’s led flashes four times.
Then press 1 & 3 together until the led flashes twice
If it switches your box on then you will need to re-pair the remote with your tv
