Discussion topic: Sky remote is not connecting to my sky box
This message was authored by: LINL8
Sky remote is not connecting to my box
Re: Sky remote is not connecting to my sky box
Hi @LINL8
First reboot your Q box.
If the remote does still not connect (with the Q box on after the reboot)
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
This message was authored by: Sarah407
No instructions coming up
