Discussion topic: Sky q wont turn on No power light
Message posted on 16 Apr 2024 06:47 PM
as if the box is broken
Message posted on 16 Apr 2024 09:10 PM
Re: Sky q wont turn on No power light
Hi @Adams1231,
Does it have an external power supply, or does it have a blue figure of 8 connector going in the back of the box (internal power supply)?
If it's the latter do you have a spare figure of 8 cable that you can test it with ?
Sky Q 2TB v2 Box + 2 Mini Boxes - Brsk BetterNet1000 FTTP, WatchGuard M400 Firewall, Plume Mesh
Sky Signature + Ultimate TV Pack, Sky Sports, Sky Cinema, Sky Kids, TNT Sports, MUTV, LFCTV, Racing TV, Premier Sports, DAZN
Message posted on 16 Apr 2024 09:54 PM
Hi solid red dot
won't do anything else
Message posted on 16 Apr 2024 09:59 PM - last edited: 16 Apr 2024 09:59 PM
Hi @Adams1231
Please try this
To complete the recovery procedure on your main Sky Q box:
- Switch the Sky Q box off at the mains.
- Hold down the standby button on the front of the box, then switch it back on at the mains.
- Keep the standby button held down until you see alternating red and amber lights on the front of the box. This will start a software update.
Please note
- The update can take up to 15 minutes, then the box will turn off and go back to a single red light.
- Your box will restart.
- After the on screen messages have disappeared, press Home on your Sky Q remote to switch your box back on.
If the screen freezes on Updating software Step 1 of 2 or Step 2 of 2 instead of going to the start up screens as expected:
- Switch the box off at the mains, then back on.
- When you see the hello start up screen hold in the standby button on the box, and you should see Updating software step 2 of 2.
Message posted on 23 Mar 2025 08:35 AM
Hi
red power light flashing , have unplugged, re powered but light still flashing.
any ideas
