Discussion topic: Sky q won’t to New sky router
Message posted on 21 Mar 2024 09:09 PM
Got a new router today and the engineer said he had connected my tv to it. Once he had left found out he hadn't connected sky q to network. Have been trying for 9 hours to connect but no luck. Updated software and went through sky help on Facebook but no. Suggested I call but now it is after 9pm and they are closed! Will have to take another day off work to call tomorrow. Any ideas what else I can try? Wishing I hadn't changed to sky. @Fiona
Message posted on 22 Mar 2024 08:19 AM
Re: Sky q won’t to New sky router
Hi @Fiona-c1
Message posted on 22 Mar 2024 01:07 PM
Thanks, tried all that and called them back. They talked me through unplugged everything then plugged in and reset but no luck. Engineer is coming tomorrow. Fingers crossed
