Discussion topic: Sky q won’t connect to network connection
This message was authored by: Zena+Ledger
My sky went off this morning and not been how to connect all day, main box is saying problem with network connection, I have don't everything by turning everything off and unplug all and still not working
Re: Sky q won’t connect to network connection
Hi @Zena+Ledger
Assume you have carried out a Network reset on your Q box exactly as follows.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
