1
This discussion topic has been answered Discussion topic: Sky q won’t connect Toshiba smart tv
This message was authored by: Mummafrostie
Sky q won't connect to Toshiba smart tv stays blank screen with no sound unless I put sky q box into standby it flickers on screen then disappears
Re: Sky q won’t connect Toshiba smart tv
Hi @Mummafrostie
First reboot you Toshiba TV.
To reboot disconnect the power lead for 30 secs then reconnect.
Once the TV is back up and running trybrebooting your Q box.
Hi @Mummafrostie
