Discussion topic: Sky q will mot connect to WiFi how do you get to speek to a real person at sky?
Message posted on 22 Jul 2023 05:08 PM
How do you speak to a real person at sky? Very close to cancelling my subscription
Message posted on 22 Jul 2023 05:25 PM
Re: Sky q will mot connect to WiFi how do you get to speek to a real person at sky?
If you need to contact them you need to persevere by phone.
To contact Sky
Select Need more help
at the bottom of the following link and this will lead to a phone contact.
Ignore all automated messages and wait for an agent
https://www.sky.com/help/home
As regards connecting to your WiFi
Assume this is your main Q box.
Try a Network Reset found in Q box Home - Settings - Setup - Network.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
