Discussion topic: Sky q switches off - 15/05
Message posted on 15 May 2025 10:14 PM
Re: Sky q switches off
This is happening to us as well. This looks like it is a SKY issue. Just hoping that the system has not been hacked!
Re: SKY Q TV NOT WORKING 15.05.25
Our sky box has turned off twice too, the minis are still working tho! 🤦♀️ so annoying!!
Message posted on 15 May 2025 10:15 PM
Mine has turned off twice tonight as well?
Sky Q keeps cutting out.
Home button doesn't work when Sky Q cuts out. Anyone else experiencing this?
Re: Missing picture
Just came here to say "me too".
Re: Sky Q stopped working at 21.45
Mine stopped working too, I reset the Q box and it did it again a few min later. Anyone know why this is happening?
Same here, Newcastle, tv shows no connectivity and box unresponsive. Only power reset brings back on but goes off again within 10-20 minutes
My sky tv doesn’t work
My sky tv has gone off and is not working at all
Message posted on 15 May 2025 10:16 PM
Re: Sky q box keeps crashing - requires full reboot
Exact same issue for me. First crash during recording watching, and second during live TV. About 30 mins apart after power cycle.
Re: Missing picture
Mine down as well. My mum's is off too. I switched it off at the wall and did a reset. It came back on but it is off again now.
Sky Q Box
Sky Q Box keeps shutting down
Same here crashed 2 times in less than 30mins Sky Q box
do you have the same WEAK OR NO SIGNAL pop up on the screen?
Sky Q box tunring off
Randomly Sky Q box has just been switching itself off in the middle watching things then it is totally frozen and have to turn it off at the mains to reboot. Started an hour and a half ago and Happened 3 times. So seems like every half hour. Software all up to date and well ventilated so not overheating. Had it in same place for 4 years. Quite annoying as watching the golf and obviously the recordings stop evertime have to reboot it all. Any advice appreciated, Also if is an issue with the box I presume sky will replace as don't own it? Thanks in advance
PICTURE LOSS BOX NOT RESPONDING
I was watching Sky Sports a playoff between Charlton and Wycombe, everything was fine and everything suddenly went off my box does not respond, it has a green light on and a red light in the centre When I press the remote, nothing happens, so I can't even get into settings on screen my broadbands fine as is my mobile just no tv whatsoever.
Any ideas anyone
