Discussion topic: Sky q stuck in standby
This message was authored by: Samw74
Ky sky q box is seuck in standby
Re: Sky q stuck in standby
Hi @Samw74
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
Avatar for Samw74
Level 0 icon
The amber light when pressed doesnt go green.  Just remains amber.  The ? Button when pressed in remote does flash.  Turnes everything off ans back on with no change.
Hi @Samw74
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
