74
This discussion topic has been answered Discussion topic: Sky q ..slow download
This message was authored by: StephDowns
I have a sky q box and I have noticed lately that when downloading from catch up.or demand its very slow to start . Remains on 0% for a while then suddenly starts . My Internet is fine and it's a wired connection . I have done the usual re boot the box but still the same . Its only been like it recently . Any ideas ?
This message was authored by: Chodley Answer
Re: Sky q ..slow download
@StephDowns wrote:
My sky q is hard wired and it makes no difference at all . And they call it progress
And you've got wifi disabled on the Q?
sorry if I asked you this before - I recognise your username.
Turned off wifi on the Q?
Avatar for StephDowns
Level 2 icon
Yes done that
Do you have any other device you can plug into that ethernet connection to double check normal downloads are
high speed?
Level 2 icon
Yes I have done that too ans speeds.via the ethernet cable and also.over wifi are great no problems.at all .
On the same cable? Hmm, have you tried a reboot and network reset?
Level 2 icon
Yes tried that a few times . Seen on another thread others are having the same problem. No solutions so far
Are they on ethernet? It's a common problem on wifi.
Level 2 icon
Yes on ethernet with me
Sure, I meant the others you were referring to?
Level 2 icon
Oh I am not sure 2 I know are the others not too sure to be honest
This message was authored by: c7cwg
I am having a similar issue
I've checked my download internet speed & i've got 130mbs, but the sky box seems to take ages.
Has anyone spoken directly to sky yet? if not i will call later today
Level 2 icon
Mine is around 274 download speed but still slow . If you speak to sky let me know and I will too . The more people ring the more likely it will get resolved.
I use ethernet into a wifi node which I think means it gets away from some of the strange networking behaviour of the Q box and I get UHD movies ready to play in sub 10 seconds. 1Gb internet connection. Also that mesh node has an indirect hop to the router too so it's not what I would call a fast connection.
I have tested direct ethernet to the router and it was equally fast (but impractical without doing some house renovations) but I didn't get to see how that behaves after a day or week.
This message was authored by: NatalieUL
I have this problem but using Wireless connectivity as my router is too far from the sky q box for a wired connection. Using Virgin Internet M250 and getting high speeds with everything apart from downloading catch up shows on Sky Q.
