This discussion topic has been answered Discussion topic: Sky q ..slow download
Message posted on 13 Dec 2023 08:25 AM
Re: Sky q ..slow download
Restarted or did a full Network Reset?
and did you keep the minis switched off to start with until the Q was working?
Message posted on 13 Dec 2023 08:44 AM
We have done a full network reset many times. We have 1 mini which has been switched off for a while and still the same issues.
It momentarily loses connection frequently with the network connection becoming a "x". By the time you've noticed it is an "x" it has gone to tick. This goes round and round in a loop causing a network reset each time then it just happens again
Message posted on 13 Dec 2023 09:00 AM
My sky q is hard wired and it makes no difference at all . And they call it progress
Message posted on 13 Dec 2023 09:06 AM
@Gemma50 wrote:We have done a full network reset many times. We have 1 mini which has been switched off for a while and still the same issues.
Yeah that was what mine did. I still had the minis on though and never tried without them powered but sounds like you have. It had always been on / off but I'd had enough of it that day, gave up on wifi and changed to this setup with a wifi mesh extender connected to the Q over ethernet and the minis using powerlines and it's been rock solid and fast ever since
I'll escalate your post anyway to see if the Sky online team here can help.
Message posted on 13 Dec 2023 09:08 AM
@StephDowns wrote:My sky q is hard wired and it makes no difference at all . And they call it progress
And you've got wifi disabled on the Q?
sorry if I asked you this before - I recognise your username.
Message posted on 13 Dec 2023 09:48 AM
Hi there! Thank you for escalating this. We have sent an invite to @Gemma50.
Message posted on 13 Dec 2023 10:38 AM
I am still having this problem.
I also have an issue watching anything (live or recorded) on the mini box, I assume it's to do with the connection because every now and then the quality drops, sometimes completely distorting the video.
I don't get it because I have sky full fibre, and the wifi speeds near the boxes are very strong (tested with phone).
Any ideas? I'd prefer to avoid hardwiring as that will require substantial work and cost.
Message posted on 13 Dec 2023 10:47 AM
Hi Gemma, I ended up with an engineer visit and he brought a Sky Booster with him. It sits next to my Broadband router (Virgin) and problem solved.
Message posted on 13 Dec 2023 07:49 PM
I can't believe that would be necessary, we're on BT Full Fibre 900. Also find it bizarre it's only just as issue 🤷♀️
Message posted on 13 Dec 2023 07:51 PM
Thank you, greatly appreciated
Message posted on 14 Dec 2023 12:16 AM - last edited: 14 Dec 2023 12:17 AM
@Gemma50 wrote:I can't believe that would be necessary, we're on BT Full Fibre 900. Also find it bizarre it's only just as issue 🤷♀️
The speed of the internet side of the connection isn't relevant to how well the wifi on the residential side works. You could have a 100Gb fibre connection and still have a challenging wifi signal in the house.
and yeah it is unreasonable how sometimes nothing seems to have changed but the Q refuses to cooperate.
Message posted on 14 Dec 2023 04:24 PM
Surely if you have to trick the sky box into thinking you've got Sky Broadband then sky are deliberately causing non Sky Broadband customers issues to try and force them over to their service? Ofcom will have a field day with this when it's reported. Hooking a sky router and it fixes the issue would indicate sky know what they are doing!
Message posted on 14 Dec 2023 04:33 PM - last edited: 14 Dec 2023 04:40 PM
@Seamus17386 wrote:Surely if you have to trick the sky box into thinking you've got Sky Broadband then sky are deliberately causing non Sky Broadband customers issues to try and force them over to their service? Ofcom will have a field day with this when it's reported. Hooking a sky router and it fixes the issue would indicate sky know what they are doing!
Don't think they have a mandate to support IEEE standards. More's the pity. They clearly work differently with sky routers because they form a mesh with them which they don't do with any 3rd parties.
But I'm not using a sky router or sky BB and I get fast downloads. So I don't believe it's intentional.
Message posted on 14 Dec 2023 06:02 PM
@Seamus17386 you dont have to trick the Q boxes into thinking you have Sky Broadband for the downloads to work there are thousands if not millions using third party ISP's with no problems.
As @Chodley says the main difference of having Sky as your ISP the Q hub or the broadband hub then these routers form part of a mesh that is generated
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 21 Dec 2023 04:24 PM
Every time I try to download Darts 2023/24 on catchup if it works very slow not had this problem in many years as a sky Q customer or doesn't download at all have done all the checks reboot check connections and wifi and ethernet also tried to download films all ok.
