This discussion topic has been answered Discussion topic: Sky q ..slow download
Message posted on 03 Sep 2023 09:49 PM
I have a sky q box and I have noticed lately that when downloading from catch up.or demand its very slow to start . Remains on 0% for a while then suddenly starts . My Internet is fine and it's a wired connection . I have done the usual re boot the box but still the same . Its only been like it recently . Any ideas ?
Message posted on 13 Dec 2023 09:08 AM
@StephDowns wrote:My sky q is hard wired and it makes no difference at all . And they call it progress
And you've got wifi disabled on the Q?
sorry if I asked you this before - I recognise your username.
Message posted on 03 Sep 2023 09:50 PM
Re: Sky q ..slow download
Turned off wifi on the Q?
Message posted on 03 Sep 2023 11:24 PM
Yes done that
Message posted on 04 Sep 2023 12:22 AM
Do you have any other device you can plug into that ethernet connection to double check normal downloads are
high speed?
Message posted on 04 Sep 2023 12:24 AM
Yes I have done that too ans speeds.via the ethernet cable and also.over wifi are great no problems.at all .
Message posted on 04 Sep 2023 12:48 AM
On the same cable? Hmm, have you tried a reboot and network reset?
Message posted on 04 Sep 2023 12:55 AM
Yes tried that a few times . Seen on another thread others are having the same problem. No solutions so far
Message posted on 04 Sep 2023 06:53 AM
Are they on ethernet? It's a common problem on wifi.
Message posted on 04 Sep 2023 08:37 AM
Yes on ethernet with me
Sure, I meant the others you were referring to?
Message posted on 04 Sep 2023 08:39 AM
Oh I am not sure 2 I know are the others not too sure to be honest
Message posted on 05 Sep 2023 10:23 AM
I am having a similar issue
I've checked my download internet speed & i've got 130mbs, but the sky box seems to take ages.
Has anyone spoken directly to sky yet? if not i will call later today
Message posted on 05 Sep 2023 10:26 AM
Mine is around 274 download speed but still slow . If you speak to sky let me know and I will too . The more people ring the more likely it will get resolved.
Message posted on 05 Sep 2023 12:14 PM
I use ethernet into a wifi node which I think means it gets away from some of the strange networking behaviour of the Q box and I get UHD movies ready to play in sub 10 seconds. 1Gb internet connection. Also that mesh node has an indirect hop to the router too so it's not what I would call a fast connection.
I have tested direct ethernet to the router and it was equally fast (but impractical without doing some house renovations) but I didn't get to see how that behaves after a day or week.
Message posted on 10 Oct 2023 06:01 PM
I have this problem but using Wireless connectivity as my router is too far from the sky q box for a wired connection. Using Virgin Internet M250 and getting high speeds with everything apart from downloading catch up shows on Sky Q.
