Discussion topic: Sky q remote working tv but not sky q box properly, very intermittent is it the qbox or the remote
This message was authored by: Knocker4
Sky q remote works volume etc on tv but the remote is not working properly on the sky q box, very intermittent, sometimes it works other times it won't. Can't scroll down to set up to program remote in again.  Is this a remote problem or a box problem
Re: Sky q remote working tv but not sky q box properly, very intermittent is it the qbox or the re
Hi @Knocker4
First reboot your Q box.
Then With the Q box on with green led try completly resetting your Bluetooth remote.
