13
This discussion topic has been answered Discussion topic: Sky q remote only works for volume and on/off
This message was authored by: Nicole999
Nothing else working - any ideas how I can reset? Batteries are fine , tv is fine
This message was authored by: ThePope27 Answer
Re: Sky q remote only works for volume and on/off
Try completly resetting your Bluetooth remote. Press and hold 7 & 9 together on the remote until it's led flashes four times. Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the remote led flashes and follow onscreen instructions to re- pair.
________________________________________________________________________________________
Sky Q 2TB v2 Box + 2 Mini Boxes - Brsk BetterNet1000 FTTP, WatchGuard M400 Firewall, Plume Mesh
Sky Signature + Ultimate TV Pack, Sky Sports, Sky Cinema, Sky Kids, TNT Sports, MUTV, LFCTV, Racing TV, Premier Sports, DAZN
Avatar for Nicole999
Thanks I've done this and it goes to 'remote set up' then continue but as the buttons aren't working I can't select 'continue'
Have you tried rebooting the box ?
Thank you! 🙏 😱😱
hi @ThePope27
Not nice to copy and paste others posts without crediting the Author
To be fair, I ripped it from skys website.
@Nicole999
Do you have another remote (from a mini box) that you can try. It may be a faulty remote control.
I suspect you have seen enough of my Posts to know that I am the author.
Bit unprofessional of you to be putting it on someone else's thread, if you have an issue PM me
Resolved with thanks ☺️
This message was authored by: anireal
Hi,
I have the same issue. Every few days my remote stops working it only controls the volume up and down once this happens the only fix is to reboot the mini box. Its becoming very frustrating having to reboot the box every few days.
Sky initially thought it was the mini box so they just sent me a new box and remote and the same issue persists.
This message was authored by: R1chard1
Tried pressing 7 with 9 etc but no onscreen message
Hi @R1chard1   All 7 & 9 does is reset the remote, there is no onscreen message.
https://www.sky.com/help/articles/sky-q-remote-help
