This discussion topic has been answered Discussion topic: Sky q remote only works for volume and on/off
Message posted on 07 Apr 2024 09:18 PM
Nothing else working - any ideas how I can reset? Batteries are fine , tv is fine
Message posted on 07 Apr 2024 09:21 PM
Try completly resetting your Bluetooth remote. Press and hold 7 & 9 together on the remote until it's led flashes four times. Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the remote led flashes and follow onscreen instructions to re- pair.
Sky Q 2TB v2 Box + 2 Mini Boxes - Brsk BetterNet1000 FTTP, WatchGuard M400 Firewall, Plume Mesh
Sky Signature + Ultimate TV Pack, Sky Sports, Sky Cinema, Sky Kids, TNT Sports, MUTV, LFCTV, Racing TV, Premier Sports, DAZN
Message posted on 07 Apr 2024 09:24 PM
Re: Sky q remote only works for volume and on/off
Thanks I've done this and it goes to 'remote set up' then continue but as the buttons aren't working I can't select 'continue'
Message posted on 07 Apr 2024 09:25 PM
Have you tried rebooting the box ?
Message posted on 07 Apr 2024 09:30 PM
Thank you! 🙏 😱😱
Message posted on 07 Apr 2024 09:31 PM
hi @ThePope27
Not nice to copy and paste others posts without crediting the Author
Message posted on 07 Apr 2024 09:32 PM
To be fair, I ripped it from skys website.
Message posted on 07 Apr 2024 09:35 PM
Do you have another remote (from a mini box) that you can try. It may be a faulty remote control.
Message posted on 07 Apr 2024 09:36 PM
I suspect you have seen enough of my Posts to know that I am the author.
Message posted on 07 Apr 2024 09:39 PM
Bit unprofessional of you to be putting it on someone else's thread, if you have an issue PM me
Message posted on 07 Apr 2024 10:32 PM
Resolved with thanks ☺️
Message posted on 04 Nov 2024 02:50 PM
Hi,
I have the same issue. Every few days my remote stops working it only controls the volume up and down once this happens the only fix is to reboot the mini box. Its becoming very frustrating having to reboot the box every few days.
Sky initially thought it was the mini box so they just sent me a new box and remote and the same issue persists.
Message posted on 23 Feb 2025 07:22 PM
Tried pressing 7 with 9 etc but no onscreen message
Message posted on 23 Feb 2025 07:40 PM
Message posted on 15 Nov 2025 07:09 AM
Low battery's ... pull out the power cable out of yer box then put straight back in.
It'll sort itself ,press the little house like it tells you and it'll be ok.
Happens now and then matey but yeh off an on again sorts it.
Any probs get back to me, I'm not a tech guy but it works for me.
Big Paul.
