8
This discussion topic has been answered Discussion topic: Sky q remote not turning on tv
This message was authored by: Elaine671
Problem started with me  rebooting my sky q box due to the Netflix Problem so many people have had. Got tv working but all apps (netflix, bbc iplayer) all disappeared. Rebooted again and now remote won't turn tv on, but sky q box is on. Can't view anything now as cant  get remote to work.Been messing with this for over ½ hr now!
Re: Sky q remote not turning on tv
@Elaine671 wrote:
Thank you. I've tried this several times now and although the red light flashes correctly on the sky remote, my tv still won't come on. So frustrating!
Hi @Elaine671
Is the Q box on with green led or is it still Amber?
hi @Elaine671
May I suggest you try a reset of your remote:
Press & Hold the 7 & 9 until the remote's light (red LED above the SKY logo button) flashes 4 times
Then press 1 & 3 together to go through to re-pair with the box and your TV - make sure it has line of sight of the box as until it is paired it uses Infrared
https://www.sky.com/help/diagnostics/sky-q-remotes/setting-up-remote
Avatar for Elaine671
hi @Elaine671
If I understand it you are unable to switcvh the TV itself on  - if so  may I sugest you use the TV's own remote to power on the TV (or physical buttons on the TV) and then see if SKY shows and follow the steps to re-pair the remote to the TV
Hi @Elaine671
Thank you very much. I have now paired up the remote and all seems to be working properly now. I appreciate your time 🙏🏼
This message was authored by: Brenda22
Hi, hi do you pair the remote to the tv
@Brenda22 Try resetting your remote.
Press the buttons 7 & 9 together on the remote until it’s led flashes four times.
Then press 1 & 3 together until the led flashes twice then follow onscreen instructions to repair the remote.
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Hi, I have tried all that, but still not working. This have happened before. When I get a new remote, it will be my third one. Thanks for replying
Answered - Go to Answer
