Discussion topic: Sky q remote / TV / BAUHN
This message was authored by: smithy8282
My TV is a BAUHN and my sky q went back to factory settings / Reset and now remote won't control the TV.     I've tired 1&3 7&9 to repair but the BAUHN setting and other settings won't work.    Does anyone know another option.
Re: Sky q remote / TV / BAUHN
Hi @smithy8282
You have to enter the codes in the correct order.
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Avatar for smithy8282
Thank you.  Yes sorry I did that.      For some reason just won't work on my TV.
Thank you.  Yes did that but the make for my tv the settings didn't work or did other brands.   It worked fine for years but stopped last night due to reset
Hi @smithy8282
Have you tried new batteries in the remote?
Then try re pairing again in Home - Settings - Setup - Remote control
Thanks @oldfella  ill try some new batteries  - sky said they will send a new remote but unsure if that will help.   Its never been an issue.
Got sent a new remote and still can connect tonTV. Only worked a few days ago?
