Discussion topic: Sky q not working but broadband is
This message was authored by: Shaun1990
My broadband is working  fine throughout the house but my sky q says it has no internet. Satellite is working.  I have tried to connect through pressing wps button on my router but no response.  If you have any suggestions please?
This message was authored by: Invisiblename
Re: Sky q not working but broadband is
Which broadband do you have? WPS only works for Sky, otherwise you need to enter your hub's password.  If this doesn't work, try:
1.  Restart your WiFi hub, then your Sky box.
2. If that doesn't work, do a Network Reset on the Sky Q.
I am just another Sky customer!
Avatar for Shaun1990
It's with sky but will try the below. Thanks
