Discussion topic: Sky q not turning on
This message was authored by: stuturner
New sky q box not turning on
Avatar for stuturner
Level 0 icon
Re: Sky q not turning on
Just arrive after the second box doesn't want to turn on from the box ridiculous
Hi @stuturner
 First reboot the Q box.
Then try pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
