Discussion topic: Sky q not downloading, stuck on 0%
Message posted on 25 Sep 2025 01:05 PM
My sky q box is stuck on 0% when downloading. I have done all resets possible with no effect. My router is fine and showing connected to the box. I have rung for technical support, only to be told that there is a problem with sky downloads and to wait 48 hours for this to be fixed. Is this right or have I been fobbed off. Also would like to know what is the next step
Message posted on 25 Sep 2025 01:06 PM
Re: Sky q not downloading, stuck on 0%
Is your broadband with TalkTalk?
Message posted on 25 Sep 2025 01:17 PM
Hi, no it is with a company called clear business. Have had sky q for over 6 months with no problem
Message posted on 25 Sep 2025 01:51 PM
Okay, there is a significant issue for some Sky Q and Sky+ customers at the moment with downloading but the common denominator has been having TalkTalk broadband which is why I asked the question.
Message posted on 25 Sep 2025 02:09 PM
Thanks, have tried the change DNS server advice and this worked... Thanks for your help
Message posted on 25 Sep 2025 02:11 PM - last edited: 25 Sep 2025 04:07 PM
Worth trying the same solution/workaround just in case they either use a talktalk service behind the scenes or are impacted by a similar dns propagation issue.
try changing the DNS server in your Q's network settings to 1.1.1.1 and then confirm and power cycle the box.
Message posted on 25 Sep 2025 02:13 PM
Thank you. Following the rest of the other posts I have changed the DNS server to 1.0.0.1 and this has fixed my problem
Message posted on 25 Sep 2025 02:52 PM
Yeah that one is fine too, those two addresses are both Cloudflare DNS servers.
Message posted on 25 Sep 2025 04:25 PM
Hi. Can you advise how I change the DNS setting?? Thanks
Message posted on 25 Sep 2025 04:36 PM
@MrFoxLCFC wrote:Hi. Can you advise how I change the DNS setting?? Thanks
https://helpforum.sky.com/t5/Sky-Q/Sky-Q-download/td-p/5096145
