Discussion topic: Sky q not connecting to hub
Message posted on 12 Apr 2024 09:09 PM
My sky q box says it is not connecting to the wifi router for catch up
Message posted on 12 Apr 2024 09:17 PM
Re: Sky q not connecting to hub
Hi @Karlheywood
