Discussion topic: Sky q not connected to router
Message posted on 10 Jan 2025 06:10 PM
I need to connect router to sky q it has disconnected for some reason and I can't use apps or any services
Message posted on 10 Jan 2025 06:15 PM
Re: Sky q not connected to router
Hi @CPS48 It is difficult to help without details, but have a look at these help pages.
Message posted on 10 Jan 2025 07:03 PM
Hi @CPS48
