Discussion topic: Sky q not compatible with new samsung f6000f tv
Message posted on 23 Nov 2025 12:39 PM
The new samsunf smart tv says the sky q box resolution is not compatible. I have tested the hdmi cable which the tv is says is okay. I have rebooted everything more than once. The tv picks up sky on both of its hdmi ports but as it goes through the set up initially showing the sky screen it repeatedly then shows the same fault code ' mode not supported'. Resolution not supported. Change resolution of external device. Other older samsung and lg tvs works. What is going on?
Message posted on 23 Nov 2025 12:46 PM
Re: Sky q not compatible with new samsung f6000f tv
Could be an issue with the TV.
However, press 'Home 1 0 8 0 Home' reset the Q resolution to the most compatible.
Message posted on 23 Nov 2025 01:08 PM - last edited: 23 Nov 2025 01:43 PM
That appears to be the Samsung number for a 'Full HD' only model, not UHD.
It's essentially an older computer monitor pretending to be a television.
https://www.tomsguide.com/tvs/samsung-f6000f-led-tv-review
Are you using it with a main Q box or a Q Mini? The default UHD output from most main Q boxes cannot be displayed by a Full HD television set.
