06 Apr 2023 07:25 PM
My sky q box keeps disconnecting,when you ring up you go through the same reconnection process,I've done this about a dozen times still it keeps happening,I was on the phone for 25 minutes today before I put the phone down, obviously some problem with the boxes,all the other WiFi equipment we have is still connected,I'm going to cancel my contract as soon as it's over, although I've been with sky for over 3 years
06 Apr 2023 07:33 PM - last edited: 06 Apr 2023 07:34 PM
Hi @Abu+j
Who is your Broadband supplier and what is the connection procedure you keep going through?
Also where is your Q box in relation to your router?
06 Apr 2023 09:46 PM
My provider is virgin,the router is 6 feet away from the mini box the procedure is what they go through when you ring up for help
06 Apr 2023 09:52 PM
Hi @Abu+j
If your mini is the issue then being 6 foot from the router is a detriment not a benefit.
The mini will not connect by WiFi to a 3rd party router. It will only connect to the WiFi from the main Q box
06 Apr 2023 09:58 PM
I've been a customer for over 3 years and this problem has only started in the past 6 months,if you go through the rigmarole of going through the steps to reconnect 9 time's out of ten it'll connect,some days it works with a problem other days it'll work for a bit , then loose connection, we'll have to do the process again and so on,really frustrating
06 Apr 2023 11:52 PM
Posted by a Superuser, not a Sky employee. Find out moreHow far away is the Q from the mini (and router)?
07 Apr 2023 06:20 AM
Hi,the main box is in the front bedroom,the mini box is directly underneath in the living room,so not far for the WiFi signal to go through the ceiling
07 Apr 2023 06:35 AM - last edited: 07 Apr 2023 06:40 AM
Posted by a Superuser, not a Sky employee. Find out moreYeah you'd think that would be ok.
Personally I gave up on wifi. (Mine are further apart) and use powerlines for the minis to connect to the Q.
And a wifi mesh to connect the Q to the router although in your case that seems like it should be overkill.
07 Apr 2023 11:33 AM
Hi mate,tell you how bad it is,just came back from the town,put sky on,guess what, needed to reconnect to main box, again,roll on September
07 Apr 2023 02:45 PM
Hi all,the minibox has disconnected again,from reading some of the other comments, I can't be the only one with this problem, someone must have a permanent solution to this
07 Apr 2023 02:52 PM
Mine is exactly the same.
Had it for a good few years now with no issue up until a few month back.
Nothing had changed in terms of router, positioning, new tech.
I'm with BT FTTP and tried wifi straight from router, tried wholehome discs and tried a Deco mesh system turning mesh on and off for the Sky Q boxes.
The boxes connect to each other fine but no internet to them, sometimes its on and then it will just disconnect randomly.
I've an engineer coming out soon so hopefully its just a faulty box but im not holding my breath.
I've gave up resetting it now, its a proper PITA.
07 Apr 2023 02:55 PM
The mini boxes do also randomly disconnect so there no sky cahnnels available i've been told 🙁
07 Apr 2023 05:38 PM
So far we've reset the boxes 3 times today,sky sent a text to receive feedback on the last call I made to them about this, needless to say I gave them a very good feedback...........NOT
08 Apr 2023 12:25 AM
@Olvr73 wrote:Mine is exactly the same.
Plug the Q into the back of a WH disc or Deco node. It will then piggyback that wifi and be stable and 10x faster.
You will probably need to do the same with the minis and turn off wifi on all of them.
08 Apr 2023 08:28 AM
Thanks , that would be the obvious fix but I dont want to use a wired connection nor have i ever since getting Sky Q around 6 years ago.
I should'nt have to do that for it to work and it . Wireless connectivity was the main reason i changed to Sky Q.
As i say though, everything has worked fine up until a couple of months ago.
